Successfully Integrating Tekmar Devices with Home Assistant
I’ve recently embarked on a project to integrate my Tekmar networked thermostats and controls into Home Assistant, and I’m thrilled with the results! :tada: Let me share my journey and some tips that might help others looking to do the same.
The Setup
I use the Tekmar Gateway 482 with tN4 communication for my thermostats and snowmelt controls. To get everything working seamlessly, I created a custom integration using the tekmar-482 repository on GitHub. Pairing this with the tekmar-packetserv add-on has been key to ensuring smooth communication over RS232.
Challenges and Solutions
Initially, I faced some hurdles with getting the add-on to run smoothly alongside my existing Home Assistant setup. Running them separately on different Raspberry Pi units with USB serial adapters proved to be the most reliable solution. I also had to tweak the configuration to ensure compatibility with my wired setup, as the integration doesn’t support Wi-Fi or cloud-based Tekmar devices.
Tips for a Successful Integration
  1. Check Compatibility: Make sure your Tekmar equipment is compatible by referring to the Compatible Equipment Wiki.
  2. Installation Steps: Install the integration via HACS or manually, and add the add-on through the add-on store. Detailed instructions are available in the GitHub repositories.
  3. Network Considerations: Ensure your gateway and Home Assistant are on the same local network for optimal performance.
The Outcome
After some trial and error, everything is now running like clockwork! I can monitor and control my thermostats and snowmelt systems directly from Home Assistant, which has greatly enhanced my smart home setup. The ability to automate heating based on temperature and occupancy has been a game-changer for energy efficiency.
If anyone has questions or needs help with their own integration, feel free to reach out! I’d be happy to share more details or troubleshoot issues together. :handshake:
