Successfully Integrating Thread and HomeKit Devices into Home Assistant
I’m thrilled to share my recent success in integrating Thread and HomeKit devices directly into Home Assistant without the need for any workarounds or hacks! :tada:
Here’s a quick rundown of the devices I’ve successfully connected:
  • Eve Room thermostat
  • Onvis 5 Button Switch
  • Eve Shutter Switch
Setup Requirements:
  • A Bluetooth adapter (I opted for an external one to avoid potential Zigbee interference)
  • A Thread-capable USB stick (I used the SkyConnect)
  • Ensure the Thread and HomeKit integrations are installed and configured in HA
  • The Home Assistant app must be set up on your smartphone
Step-by-Step Process:
  1. Credentials Sharing: I started by sharing the credentials of my Apple Thread network with Home Assistant through the Home Assistant app. This was crucial for seamless integration.
  2. Adding Devices via Bluetooth: Following the official documentation, I added the HomeKit devices through Bluetooth. The process was straightforward and eliminated the need for any network hacking.
  3. Thread Integration: Once the devices were recognized via Bluetooth, I seamlessly integrated them into the Thread network using HA’s built-in features.
Outcome:
Everything works like a charm! The devices are responsive, and the integration is stable. It’s amazing how smooth the process was once I had the right setup in place.
Why This Matters:
For anyone looking to transition to Thread or integrate HomeKit devices, this method offers a clean, efficient solution. It’s a testament to how far the Home Assistant community has come in supporting cutting-edge technologies like Thread.
I’d love to hear from others who’ve had similar experiences or if anyone has tips for troubleshooting common issues! :hugs:
Does this make the thread devices a part of the HomeKit thread network or does it create it’s own?
Surely you don’t need the Thread USB stick as you just tell it to use the Apple Thread network. Then it communicates via IP. Isn’t that correct?
