I recently decided to integrate my Torque app with Home Assistant to monitor my car’s diagnostics. Initially, I found the setup a bit overwhelming, but after some research and experimentation, I managed to get everything working smoothly. Here’s how I did it, in case anyone else is looking to do the same!
Step 1: Preparing Your Home Assistant
First, I edited my configuration.yaml file to include the necessary settings for Torque integration. It was crucial to add my email address, even though it didn’t seem important at first. I also created a Long-Lived Access Token in my HA user settings, which was a bit nerve-wracking since I had to handle it carefully to avoid losing access.
Step 2: Configuring the Torque App
Next, I delved into the Torque app settings. I had to enable data logging and upload, which involved selecting the right parameters and ensuring the webserver URL was correctly formatted with my HA address. The most nerve-wracking part was setting the Bearer Token and user email—getting those wrong meant starting over, which I definitely wanted to avoid!
Step 3: Testing and Troubleshooting
After setting everything up, I connected my OBDII adapter and went for a short drive to generate some data. It was a bit anticlimactic at first when nothing showed up in HA, but after double-checking all the settings, the sensors finally appeared. It was such a relief to see all the car data in my HA dashboard!
Tips for Success
- Patience is Key: Don’t rush through the steps. Take your time to verify each setting.
- Use Google Keep: Store your token and important details somewhere safe to avoid losing them.
- Test with Real Data: Driving for a bit ensures you get accurate readings and catch any issues early.
I hope this guide helps others integrate Torque with their Home Assistant setups. It’s a fantastic way to keep tabs on your car’s health right from your smart home system! ![]()
