Hey everyone, I wanted to share my experience with integrating TP-Link devices across different Wi-Fi networks. I recently faced a challenge where one of my TP-Link devices wasn’t showing up in Home Assistant because it was on a different network. After some research and experimentation, I found a workaround that works well for me, and I thought I’d share it in case others are dealing with a similar issue.
The Challenge:
I have several TP-Link devices, but one of them, let’s call it Device A, was on a different Wi-Fi network due to signal issues. While Device A was visible in the TP-Link Kasa app, it didn’t show up in Home Assistant. This meant I couldn’t control it through my smart home setup, which was a bit frustrating.
The Solution:
I decided to create an automation in the TP-Link Kasa app. The idea was to have Device A turn on or off based on the state of another device, Device B, which was on the same network as Home Assistant. Here’s how I set it up:
Automation in TP-Link Kasa:
- I created an automation in the Kasa app that triggers Device A to turn on when Device B is on and vice versa. This essentially mimics the behavior of Device B to control Device A.
Integration with Home Assistant:
- In Home Assistant, I set up automations using Device B. Whenever Device B changes state, it sends a signal to the TP-Link Kasa app, which then adjusts Device A accordingly.
Why It Works:
This setup allows me to control Device A indirectly through Device B, effectively bridging the gap between the two networks. It’s not a perfect solution, but it gets the job done without requiring additional hardware or complex configurations.
Tips for Others:
- If you’re dealing with devices on different networks, consider creating a similar automation setup. It might not be the most elegant solution, but it can provide the functionality you need until a better option becomes available.
- Always test your automations thoroughly to ensure they work as expected. Sometimes, timing or network delays can cause unexpected behavior.
Looking Forward:
I’m hopeful that future updates to TP-Link’s integration with Home Assistant will allow for better handling of devices on different networks. In the meantime, this workaround has been a lifesaver for me!
If anyone has alternative solutions or improvements to this approach, I’d love to hear about them. Happy automating! ![]()
