I wanted to share my recent success in integrating Tuya XR3 humidity sensors into Home Assistant. After struggling for quite some time, I finally found a solution using the Homebridge integration. While it wasn’t a straightforward process, the end result has been fantastic!
Here’s a quick overview of what I did:
- Research: I came across the Homebridge Tuya integration and decided to give it a try. The documentation was a bit sparse, but I managed to piece together the necessary steps.
- Setup: I had to modify two files in the Homebridge Tuya package:
index.jsandhumidtysensor.js. Theindex.jswas relatively straightforward, but thehumidtysensor.jsfile required some custom coding to ensure it communicated properly with my sensors. - Testing: After making the changes, I tested the setup extensively. It took a few iterations, but the sensors are now updating consistently in Home Assistant.
This experience taught me the importance of persistence and the value of community support. If anyone else is struggling with Tuya sensors, I’d be happy to share my modified files or provide guidance!
It’s amazing how a little bit of tinkering can turn a frustrating problem into a smooth solution. I’m now looking forward to expanding my setup with more sensors and automations. ![]()
