Hi everyone, I wanted to share my recent success with integrating a Tuya smart socket into my home automation setup using ESPHome. This project was a mix of excitement, some trial and error, and ultimately a great learning experience!Background I’ve been exploring ways to expand my smart home setup without relying solely on branded devices. When I came across some Tuya-based smart sockets at a local store, I saw an opportunity to experiment. These devices were promising, but they weren’t natively supported by my system, so I decided to take the DIY route.The Process The journey began with some research. I discovered that by flashing custom firmware using ESPHome, I could unlock the full potential of these devices. Here’s what I did:1. Hardware Setup - I used a USB-to-UART converter and a 3.3V power supply to connect to the socket’s PCB. - Carefully soldering the necessary wires was a bit nerve-wracking, but it paid off!2. Flashing Firmware - Running ESPHome’s dashboard, I followed the on-screen instructions to flash the firmware. - The trickiest part was shorting the CEN pin to ground during the flashing process. It took a couple of tries, but patience won the day!3. Configuration - Using ESPHome’s configuration platform, I set up the device to control the relay, monitor power usage, and even integrate a button for manual toggling. - The detailed configuration file I created is available on GitHub for anyone interested in replicating this setup.Results and Reflections After overcoming the initial hurdles, the outcome was fantastic! The socket now seamlessly integrates with my smart home ecosystem, providing real-time power monitoring and reliable switching. It’s been a great addition to my setup.This project reinforced my belief in the power of open-source solutions and the joy of DIY. It also highlighted the importance of careful planning and patience when working with hardware.Encouragement for Others If you’re considering a similar project, my advice is to start small, do your research, and don’t be afraid to ask for help in forums like this. The sense of accomplishment when you bring a device into your smart home ecosystem is truly rewarding!Happy tinkering everyone! ![]()
