I’ve recently embarked on a home security project that involves setting up two separate Blink camera systems on the same WiFi network. While this might seem straightforward, I wanted to share my journey and insights in case others are considering a similar setup. This post is all about sharing my experience, tips, and lessons learned.### The SetupI have two Blink camera systems:- System 1: 2 Blink cameras (#1 & #2), 1 Sync Module (#1), and the Blink App installed on my iPhone under my Apple ID.- System 2: 2 Blink cameras (#3 & #4), 1 Sync Module (#2), and the Blink App installed on a different iPhone under a different Apple ID.The goal was to have each system operate independently on the same WiFi network. When using the app, I wanted to ensure that I could only view the cameras specific to each system without any overlap.### Challenges and Solutions1. Independence of Systems: The biggest concern was ensuring that the two systems wouldn’t interfere with each other. I was worried that cameras from one system might appear in the other. However, by using separate Apple IDs and ensuring each system was properly configured, I managed to keep them entirely independent.2. WiFi Network Stability: Initially, I was concerned about network congestion with four cameras and two Sync Modules. But Blink’s system seems robust enough to handle this without any noticeable lag or connectivity issues.3. App Configuration: Setting up the Blink App on two different devices was a bit time-consuming, but the process was straightforward. The key was to ensure that each app was logged in under the correct Apple ID and that each system was properly paired with its respective Sync Module.### Tips for Others- Use Separate Accounts: If you’re setting up multiple Blink systems, using separate Apple IDs (or Google Accounts if you’re using Android) is crucial to keep systems independent.- Label Cameras Clearly: I found it helpful to rename my cameras in the app to reflect their location or purpose. This avoids confusion, especially if you’re managing multiple systems.- Test Connectivity: Before finalizing your setup, test each system independently to ensure everything is working as expected.### ConclusionSetting up two Blink camera systems on the same WiFi network was a smooth process once I understood the configuration requirements. It’s a great way to scale your home security without the need for separate networks or complex setups. If you’re considering this, I’d say go for it—it’s well worth the effort!Any questions or additional tips? I’d love to hear from you in the comments below. Happy Blinking! ![]()
