I’ve recently been working on integrating some weather sensors into my Home Assistant setup, and I thought I’d share my experience in case it helps anyone else out there. First off, I wanted to monitor both temperature and humidity outside my house, but the challenge was getting the data into my local HA dashboard. I tried setting up a MQTT bridge using Adafruit.io, which worked perfectly for pushing data from my sensors to their servers. However, pulling that data back into HA proved to be a bit of a headache.
The issue I ran into was with the MQTT subscription. Every 5 seconds, the connection would drop and reconnect, causing me to miss out on a lot of the sensor readings. After spending way too much time troubleshooting, I decided to think outside the box. Instead of relying on the MQTT bridge, I wondered if HA could periodically check Adafruit.io for updates. Turns out, it can! I set up a simple automation that runs every 15 minutes, fetching the latest data from Adafruit and updating my HA sensors accordingly.
Here’s how I did it:
- Set up the sensor on Adafruit.io: This was straightforward. I used their MQTT service to publish my sensor data.
- Create a custom sensor in HA: I used a template sensor to pull the data from Adafruit. Here’s a snippet of my configuration:
yaml
sensor:
- platform: template
sensors:
weather_sensor:
friendly_name: “Outdoor Weather”
value_template: ‘{{ state_attr(‘sensor.meteoalarm_stuttgart’, ‘event’) }}’
- Automate the data fetch: I set up an automation that runs every 15 minutes, triggering a service call to update the sensor data from Adafruit.io.
The result has been fantastic. I now have reliable weather data displayed right alongside my other smart home metrics. If anyone else is struggling with MQTT subscriptions or data fetching, I highly recommend exploring this method. It’s a bit of a workaround, but it gets the job done!
Looking ahead, I’m excited to expand this setup. Maybe adding more sensors or even integrating some environmental data visualization. The possibilities are endless, and it’s all thanks to the flexibility of Home Assistant and the support from the community. Happy automating everyone! ![]()
