Successfully Integrating WLED Devices into Home Assistant - A Step-by-Step Guide
Hello fellow Home Assistant enthusiasts! I’m thrilled to share my successful experience integrating WLED devices into my Home Assistant setup. This journey has been both exciting and educational, and I’m eager to pass on the knowledge to help others achieve the same results.
Introduction to WLED and Home Assistant Integration
WLED is an open-source firmware for LED controllers that offers a wide range of customization options, making it a favorite among DIY enthusiasts. Integrating WLED into Home Assistant allows you to control your LED strips and devices directly from your dashboard, automate scenes, and even monitor temperature if you have the right setup. In this guide, I’ll walk you through the process I followed to achieve seamless integration.
Prerequisites
Before diving into the integration, ensure you have the following:
- A Home Assistant installation (supervised is recommended for ease of use).
- At least one WLED device (I used a WLED-enabled LED strip).
- Network connectivity between your Home Assistant instance and your WLED device.
- Basic familiarity with Home Assistant’s configuration files and add-ons.
Step 1: Adding WLED Devices to Home Assistant
- Discovery: Home Assistant typically auto-discovers WLED devices if they are on the same network. If your device isn’t detected, you can manually add it by navigating to Settings > Integrations > Add Integration and selecting the WLED integration.
- Configuration: Enter your WLED device’s IP address when prompted. Home Assistant will handle the rest, creating entities for your device such as
light.wled_device_name.
Step 2: Customizing WLED Presets
One of the standout features of WLED is its ability to create and store custom light presets. To control these presets directly from Home Assistant, follow these steps:
- Create Preset Dropdown: Use the Input Select integration in Home Assistant to create a dropdown menu for your WLED presets. This allows you to switch between different light modes effortlessly.
- Automate Preset Changes: Utilize Home Assistant’s automation capabilities to trigger preset changes based on events, such as sunset or motion detection. This adds a layer of smart automation to your lighting setup.
Step 3: Adding Temperature Monitoring
If your WLED device is equipped with a temperature sensor (like the QuinLED Dig Uno), you can monitor the temperature directly within Home Assistant:
- Install Custom Firmware: Upload a custom WLED firmware that supports temperature reading to your device. This can often be done through the WLED web interface under the OTA update section.
- Configure Rest Sensor: Add a Rest sensor in Home Assistant to pull temperature data from your WLED device. This involves editing your
configuration.yamlfile to include the appropriate REST API configuration.
Step 4: Enhancing the User Experience
To make your WLED integration even more user-friendly, consider the following enhancements:
- Create Lovelace Cards: Design custom Lovelace cards to display your WLED devices and their controls in an organized manner. You can include sliders for brightness, dropdowns for presets, and even iframe cards to access the WLED web interface directly from Home Assistant.
- Add Nightlight and Sync Features: Enable nightlight mode on your WLED devices for subtle ambiance during the night. Additionally, use the sync feature to ensure your WLED devices stay in sync with each other.
Step 5: Testing and Fine-Tuning
After setting everything up, spend some time testing each feature to ensure everything works as expected. Adjust automations, presets, and brightness levels as needed to perfect your setup.
Conclusion
Integrating WLED devices into Home Assistant is a fantastic way to elevate your smart home lighting setup. With the ability to create custom presets, monitor temperatures, and automate scenes, the possibilities are endless. I hope this guide has been helpful and inspires others to explore the world of WLED and Home Assistant integration.
If you have any questions or need further assistance, feel free to reach out in the comments below. Happy tinkering! ![]()
