I’ve recently been on a bit of a home automation journey, and I wanted to share my experience with integrating Wyze Light Bulb Colors into my sleep and wake-up routines. Initially, I encountered some frustration when trying to set up these routines. Every attempt resulted in an error message: “Add Wakeup Failed” or “Add Sleep Failed.” Despite troubleshooting—rebooting the bulbs, resetting them to factory settings, and ensuring they were on the same network as my phone—I couldn’t get the routines to save properly.
After some research and reaching out to the community, I discovered that the issue might be related to how the bulbs were paired or the specific firmware version. I decided to try a fresh install, ensuring that the bulbs were correctly paired with my hub and that the latest firmware was installed. To my delight, this solved the problem! Now, my Wyze bulbs seamlessly integrate with my sleep and wake-up routines, creating a comforting transition at the end of the day and a gentle wake-up in the morning.
It’s been a great learning experience, and I’m thrilled to have this feature working as intended. If anyone else is struggling with similar issues, I’d recommend checking the firmware version and ensuring a clean pairing process. Happy automating! ![]()
