Hi everyone, I wanted to share my recent success in integrating Xiaomi (Aqara) temperature and humidity sensors with OpenHAB. I’ve been exploring home automation for a while now, and OpenHAB has been a fantastic choice for its flexibility and extensive support for various devices.
Initially, I faced some challenges with getting the humidity sensor to work properly. I was using OpenHAB 2.4 with the Deconz binding, and while the temperature sensor worked out of the box, the humidity sensor wasn’t showing up in the system. After some research and troubleshooting, here’s what I figured out:
- Check the Binding Version: Ensure that your Deconz binding is up to date. Older versions might not support all features of the Xiaomi sensors.
- Verify Zigbee IDs: Double-check that the Zigbee IDs for both the temperature and humidity sensors are correctly configured in your items file. A small typo can cause big issues!
- Configuration in Paper UI: OpenHAB’s Paper UI is incredibly user-friendly. I found that manually adding the sensor under the Deconz section helped, even though it was supposed to be auto-detected.
- Zigbee Network Health: Make sure your Zigbee network is stable. Sometimes, interference or network instability can prevent devices from pairing correctly.
After resolving these issues, both the temperature and humidity sensors are now working seamlessly. It’s amazing to see real-time updates on my dashboard, and it’s giving me a better understanding of how to optimize my home’s environment.
For anyone else struggling with similar issues, don’t hesitate to reach out. The OpenHAB community is incredibly supportive, and there are plenty of resources available to help you troubleshoot. Happy automating! ![]()
