I’ve been on a journey to create a truly seamless smart lighting system, and I’m excited to share my experiences and insights with the community. My setup includes a mix of Zigbee and Wi-Fi lamps, all managed through Home Assistant. While the journey has had its bumps, the results have been nothing short of amazing.
Initially, I grouped all my lights using the Light Group Helper in Home Assistant. I have four Wi-Fi lamps, three Zigbee lamps (configured through Zigbee2MQTT), and even a switch converted to a light using a helper. The goal was to control all these lights with a single button press, whether it’s through a dashboard button or a physical IKEA Styrbar switch. However, I encountered an odd issue where one of the Wi-Fi lamps wouldn’t turn off when using the physical button, though it worked flawlessly with the dashboard button. This inconsistency was perplexing!
After some research and trial and error, I realized that the method of calling the action might differ between the dashboard and the physical button. This led me to question whether grouping the lights was the most reliable approach or if sending individual commands to each lamp would yield better results. I decided to test both methods and document my findings.
One of the key takeaways from this experience is the importance of understanding how different control methods interact with your smart devices. It’s also been a great reminder that while grouping devices can simplify control, it’s essential to ensure that all devices respond consistently across all interfaces. I’m now exploring the possibility of creating separate automations for each lamp to see if that resolves the inconsistency issue.
This journey has not only deepened my understanding of Home Assistant and smart lighting but has also highlighted the importance of thorough testing and configuration. I’m eager to hear from others who might have faced similar challenges or have insights to share. Let’s continue to learn and grow together in the world of smart home automation!
Cheers to creating a smarter, more connected home!
