Hi everyone, I wanted to share my success story in integrating Zigbee devices across different floors using Homey. After facing numerous challenges with unstable connections and devices not being recognized, I decided to take a systematic approach to building a robust Zigbee mesh network.First, I identified key locations for placing routers. I learned that placing routers at strategic points, like the center of each floor, significantly improves signal strength and reduces timeouts. This approach ensured that my Zigbee network could cover both the ground floor and the first floor effectively.I also experimented with adding a second Homey unit, which acted as a secondary coordinator. This setup helped balance the network load and improved reliability. While it was a bit of an investment, the peace of mind it provides is invaluable.For those considering a similar setup, here are some tips:- Start with a solid foundation: Place routers in central locations to ensure maximum coverage.- Monitor network health: Regularly check the network status in the Homey app to identify and address any issues early.- Consider adding a secondary coordinator: If your home layout is complex, a second Homey can help maintain a stable network.This project has been a rewarding journey, and I’m thrilled to see everything working seamlessly now. It’s a great reminder that with patience and the right approach, even complex setups can be achieved!
