Successfully Integrating Zigbee Devices with Conbee Stick
I’ve recently embarked on a journey to integrate my Zigbee devices into my Home Assistant setup, and I wanted to share my experience in case it helps anyone else facing similar challenges. :rocket:
The Challenge:
I own a mix of 7 Zigbee switches, 3 sensors, and 17 bulbs, all from Hue. While they work seamlessly on their own, I wanted to centralize their control through Home Assistant. I explored several Zigbee sticks, including the EFR32MG21 and CC2531, but faced issues with compatibility and device support. The CC2531, for instance, struggled to handle the load of 27 devices, leading to frequent disconnections. :sweat:
The Solution:
After some research, I stumbled upon the TI cc2652p stick, which uses ZStack3 and is known for its robust performance. Although it wasn’t natively supported by Home Assistant, the community’s support and documentation made it manageable. I followed a detailed guide from the forum, which involved tweaking the Zigbee2MQTT configuration to ensure optimal performance. :hammer_and_wrench:
The Outcome:
It’s been a week since I set everything up, and I’m thrilled to report that all my devices are functioning perfectly! The cc2652p has handled the load effortlessly, and I’ve even managed to automate my lighting and switches through simple scenes in HA. My wife, who prefers a user-friendly interface, loves how easy it is to adjust schedules through the dashboard. :tada:
Tips for Others:
  1. Research Thoroughly: Spend time reading through forums and documentation to find the best hardware for your setup.
  2. Leverage Community Resources: The Home Assistant community is incredibly supportive. Don’t hesitate to ask for help or share your progress.
  3. Start Small: If you’re new, begin with a few devices and gradually scale up as you become more comfortable. :rocket:
A huge thank you to everyone in the community who contributed to these solutions. It’s amazing how a little help can turn a daunting task into a rewarding experience! :pray:
If anyone has questions or needs advice, feel free to reach out. Let’s keep the smart home revolution going! :bulb:
