Hey everyone, I wanted to share my recent experience with integrating Zigbee lights using the count function. I’ve been exploring Home Assistant and decided to set up a system where a single switch can control two different lights on separate devices. At first, I was a bit overwhelmed, but with some research and the help of the community, I managed to figure it out!
Initially, I wasn’t sure how to use the count function as a condition. I stumbled upon some helpful posts that explained how to structure the automation. The key was understanding how to reference the state changes and map them correctly. I spent a lot of time testing different configurations, and it was frustrating when things didn’t work as expected. But persistence paid off!
Here’s a quick overview of what I did:
- Identified the entities for both lights.
- Set up an automation that triggers when the switch is toggled.
- Used the count function to track the number of times the switch has been pressed.
- Mapped the count values to turn on or off each light accordingly.
It’s amazing how such a small change can make a big difference in the functionality of my setup. I’m now able to control both lights seamlessly with just one switch. This experience has not only boosted my confidence in using Home Assistant but also highlighted the importance of community support.
If anyone else is looking to do something similar, I’d be happy to share more details or help troubleshoot issues. Happy automating! ![]()
