Successfully Integrating Zigbee Lights with SmartThings
After spending several hours troubleshooting, I finally managed to integrate my Zigbee lights with SmartThings! :tada: I wanted to share my experience in case others are facing similar challenges or looking for a seamless integration solution.I started by purchasing Zigbee dowlights from AliExpress and confirmed they were compatible with MC’s zigbee light Edge driver. However, I encountered significant delays in response times, especially when controlling multiple lights simultaneously. This was frustrating, as I expected a smoother experience.Through extensive research and experimentation, I discovered that organizing the lights into smaller groups or using mirror groups improved responsiveness. I also found that controlling each light individually within routines yielded better results. While it wasn’t a perfect solution, it made the system usable for my needs.Here are some tips for anyone looking to integrate Zigbee lights with SmartThings:- Start Small: Begin with a single light to ensure compatibility before expanding.- Experiment with Grouping: Try different group configurations to find what works best for your setup.- Use Routines: Incorporate lights into routines for consistent and reliable control.If you’ve successfully integrated Zigbee lights or have tips to share, I’d love to hear about your experiences! Let’s keep the conversation going and help each other achieve those perfect smart home setups. :star2:
