After dealing with the frustrating API issues of MyQ, I decided it was time to take matters into my own hands. I’ve always been a fan of MQTT and HA, so integrating ESPHome seemed like the perfect solution. Here’s how I transformed my garage door setup into a reliable, DIY-friendly system.The Challenge My MyQ garage door opener had been working fine for a while, but lately, it’s been plagued with API errors and server issues. I couldn’t risk my garage door not responding when I needed it most. Plus, I wanted more control over the integration with my HA setup.The Solution I decided to repurpose an old ESP8266 module I had lying around. The goal was to create a system that could trigger the garage door opener using a remote control I already had. Here’s how I did it:1. Hardware Setup - I used an ESP8266 module (specifically a NodeMCU) to handle the logic. - A solid-state relay was essential to control the remote’s button. - A breadboard helped keep everything organized without soldering.2. Wiring the Remote - After carefully disassembling the remote, I identified the switch that controls the button press. - By soldering wires to the contacts of this switch, I could simulate a button press programmatically.3. ESPHome Configuration - I wrote a simple ESPHome YAML configuration to expose the relay as a switch in HA. - This involved setting up MQTT integration and ensuring the device was properly flashed.4. HA Integration - I created scripts to handle the opening and closing of the garage door. - Using a cover template, I integrated everything into the HA UI, making it seamless to use.The Results The system works flawlessly! I can now control my garage door directly from HA without relying on MyQ’s shaky API. Plus, having the door status reported via a magnetic reed switch gives me peace of mind.Why This Matters This project not only solved my immediate problem but also highlighted the flexibility of ESPHome and MQTT. It’s a great example of how open-source solutions can empower users to take control of their smart home setups.If you’re facing similar issues with proprietary systems, I highly recommend exploring DIY solutions. The learning curve is worth it, and the satisfaction of a successful project is unbeatable!DIY #ESPHome #MQTT #SmartGarage
