After spending weeks researching and preparing, I finally decided to upgrade my Veralite UI5 to Veraplus. The decision wasn’t easy, especially after reading about some users’ challenges. However, I wanted to take advantage of the newer features and improvements that Veraplus offers. Here’s my journey and some tips I’ve gathered along the way!
The Initial Hurdles
Before diving in, I had several questions:
- Should I upgrade my Veralite to UI7 first?
- How would my existing configuration, with all its devices, scenes, and Lua code, transfer over?
- What about account issues? Would I need a new account or could I use my existing one?
I reached out to the community and did some digging, and here’s what I found:
- Upgrading First: Upgrading your Veralite to UI7 before the migration seems to be a good first step. It ensures compatibility and a smoother transition.
- Configuration Transfer: While a fresh install might seem daunting, especially with a large setup, there are tools and guides available to help propagate your configuration from Veralite to Veraplus. I recommend reaching out to the support team for detailed steps.
- Account Concerns: Most users reported that their existing accounts worked fine, but it’s always a good idea to have a backup plan just in case.
The Migration Process
The migration itself was a mix of excitement and anxiety. I decided to go with a fresh install, carefully backing up all my configurations first. To my relief, the process was smoother than I expected, thanks to the detailed guides I found online.
One thing I learned is the importance of testing each device and scene after migration. It’s time-consuming, but it ensures everything works as intended. I also discovered that some custom Lua scripts needed tweaking, but the community was incredibly helpful in providing solutions.
Tips for a Successful Migration
- Backup Everything: Before starting, make sure you have a complete backup of your current setup.
- Plan Ahead: Decide whether you’ll go for a fresh install or a configuration transfer. Each has its pros and cons.
- Community Support: Don’t hesitate to reach out to forums and communities. The collective knowledge is invaluable.
- Patience: Migration can take time, especially with a complex setup. Take it step by step and don’t rush.
My Veraplus has been up and running for a few weeks now, and I’m thrilled with the results. The new interface is user-friendly, and the additional features have enhanced my home automation setup. While the migration process had its challenges, the end result has been worth it.
If you’re considering an upgrade, my advice is to do your research, plan carefully, and don’t hesitate to seek help when needed. The journey might be a bit bumpy, but the destination is definitely worth it!
Happy automating! ![]()
