I recently found myself in a situation where I needed to migrate my HC2 configuration to a brand new unit. While the process seemed daunting at first, I managed to pull it off without any major hiccups. Here’s how I did it, along with some tips that might help others in a similar boat.
First off, I read through the official migration guide provided by Fibaro. It was a solid starting point, but I wanted to make sure I understood every step thoroughly before diving in. One thing I noticed was the importance of firmware versions. The guide emphasized that both the donor and target HC2 units need to be on the same firmware level. I couldn’t agree more—this step is non-negotiable. I spent a good chunk of time ensuring both units were up to date before proceeding.
Next, I tackled the Fibaro ID synchronization. This part was a bit confusing at first, but I realized it’s all about patience. I connected the new HC2 to my network and went through the setup process as if it were a fresh install. However, instead of starting from scratch, I used the Fibaro ID from my existing HC2. This step was crucial because it allowed the new unit to recognize all my existing devices and configurations without any issues.
One thing I was particularly worried about was losing any custom settings or automations. To mitigate this, I made sure to back up everything before starting the migration. I used the built-in backup tool in the HC2 interface and stored the backups in a safe location. It’s a simple step, but it gave me peace of mind knowing that I could restore anything if things went south.
After the migration was complete, I spent some time testing each device and automation to ensure everything was working as expected. I was pleasantly surprised at how seamless the process was. The only hiccup I encountered was a minor issue with one of my smart cameras, but that was quickly resolved by re-syncing it with the new HC2.
For anyone planning to undertake this process, here are my top tips:
- Backup Everything: It can’t be stressed enough. Having a solid backup is your safety net.
- Firmware First: Ensure both units are on the same firmware version before you begin.
- Patience is Key: Take your time with each step, especially when dealing with Fibaro IDs and backups.
- Test Post-Migration: Don’t assume everything works. Take the time to verify each device and automation.
In conclusion, migrating an HC2 configuration to a new unit is definitely doable, but it requires careful planning and execution. By following the guide and keeping these tips in mind, you can make the process much smoother. If you have any questions or need advice, don’t hesitate to reach out—I’m happy to help!
Cheers,
Brian
