After hearing the news about Iris by Lowe’s ceasing operations, I decided to take proactive steps to ensure my smart home setup wouldn’t be disrupted. The journey of migrating my Iris devices to OpenHab was both challenging and rewarding, and I’m excited to share my experience with you.### Initial Setup and ResearchI started by researching the compatibility of my Iris devices with OpenHab. My setup includes Gen1 window/door sensors, a Gen2 hub, and a couple of Zigbee fire alarms. I was relieved to find that OpenHab supports these devices through its Z-Wave binding. However, I knew I’d need to configure everything properly to ensure seamless integration.### Hardware PreparationI already had a Raspberry Pi setup, so I decided to use a Raspberry Pi 3 Model B for this project. I installed OpenHabian on it, which made the process much smoother. I also ensured that my Raspberry Pi was connected to a stable power source and placed in a location with optimal network coverage.### Firmware and Software UpdatesBefore diving into the setup, I updated all my Iris devices to the latest firmware. This step is crucial to ensure compatibility and avoid any potential issues during the migration. I also updated OpenHab to the latest version to take advantage of the newest features and bug fixes.### Configuring OpenHab1. Adding the Z-Wave Binding I enabled the Z-Wave binding in OpenHab and configured it to use my Raspberry Pi’s serial port. This involved editing the services/zwave.cfg file to specify the correct port and baud rate.2. Including Devices I followed the standard Z-Wave inclusion process. Each Iris device was added one by one, ensuring that they were properly recognized by OpenHab. I used the OpenHab Paper UI to monitor the inclusion process and verify that all devices were successfully added.3. Testing Device Functionality After adding all devices, I tested each one to ensure they were functioning correctly. I used the OpenHab sitemap to create a simple interface for controlling my devices and monitoring their statuses.### Challenges and Solutions- Firmware Compatibility Issues Initially, I faced some issues with the Zigbee fire alarms not being recognized. After some research, I discovered that updating the firmware on these devices resolved the problem.- Network Stability I noticed that some devices would occasionally drop off the network. To address this, I optimized my home’s Wi-Fi setup by changing the channel to one with less interference and ensuring that all devices were within optimal range of the hub.### Tips for a Smooth Migration1. Backup Your Current Setup Before making any changes, ensure you have a complete backup of your current Iris setup. This will allow you to restore your devices if any issues arise during the migration.2. Plan Your Configuration Take the time to map out how you want your devices to interact within OpenHab. This will save you time and frustration during the setup process.3. Test Incrementally Add and test one device at a time. This approach allows you to identify and resolve any issues early on, preventing potential headaches down the line.### Final ThoughtsMigrating my Iris devices to OpenHab was a successful endeavor that has given me more control and flexibility over my smart home setup. OpenHab’s robust ecosystem and extensive community support made the transition smoother than I anticipated. I encourage anyone facing similar challenges to give OpenHab a try—it’s a fantastic platform for home automation enthusiasts.If you have any questions or need assistance with your own migration, feel free to reach out. Happy automating! ![]()
