Hey everyone, I wanted to share my recent experience migrating from my old setup to Home Assistant OS (HA OS). It’s been a journey filled with both challenges and triumphs, and I thought I’d walk through it here to hopefully help others who might be considering a similar move.
The Setup
I started with a NUC i3 running Debian 11.x Buster with Docker containers, formerly using hass.io. After a full backup from the GUI, I decided to go all-in with HA OS 10.1 on a new Samsung m.2 NVME SSD. The installation via Balena Etcher went smoothly, and I was up and running with DHCP for the IP address and homeassistant.local for DNS. Using the CLI, I set a static IP, adjusted DNS servers, and updated the DNS node name. A reboot confirmed most settings were intact, but there was one hurdle I couldn’t overlook—LAN access.
The Challenge
Initially, I couldn’t access the HA server from within my local LAN. The GUI loaded initially but then failed to complete. This was perplexing because the DuckDNS and Let’s Encrypt setup worked perfectly outside the LAN. My phone’s HA Companion app worked fine when Wi-Fi was off, but without LAN access, it was a bit of a dead end. I knew SSH access was crucial for troubleshooting, but it wasn’t straightforward.
Troubleshooting
I checked my Asus AX router with Merlin firmware 388.2_2. Hairpin NAT was active, and the NUC had a static IP. DuckDNS was correctly set with the external IP. I tried resetting the HA server, adjusting firewall settings, and even reinstalling the OS. Nothing worked until I considered the possibility of a firmware issue on the router. After a firmware update and a fresh setup, LAN access was restored!
The Solution
It turned out the router’s firmware needed an update to support the newer HA OS features properly. Once that was done, everything fell into place. I could access the GUI from within the LAN, and SSH was available for deeper troubleshooting. This experience taught me the importance of keeping firmware updated, especially when dealing with newer systems.
Lessons Learned
- Backup First: Always ensure you have a complete backup before making significant changes.
- Check Firmware: Outdated firmware can cause unexpected issues, especially with new setups.
- Network Configuration: Double-check router settings, especially NAT and firewall configurations.
- Community Support: Don’t hesitate to reach out to forums or communities for help. Often, others have faced similar issues and can provide valuable insights.
Looking Forward
Now that everything is up and running, I’m excited to explore more advanced features of HA OS. I plan to integrate more devices and experiment with automations. It’s a thrilling time to be diving into the world of smart home technology!
If anyone has questions or needs advice on migrating to HA OS or troubleshooting LAN access, feel free to reach out. I’m happy to share what I’ve learned and help others on their journey.
Cheers,
