After spending several years with SmartThings, I decided it was time for a change. I’ve always been intrigued by Hubitat’s flexibility and the vibrant community support. My journey began with a simple goal: to migrate my existing Zemismart zigbee switches, including some multi-gang ones, to Hubitat. While the process had its challenges, it was ultimately a rewarding experience.
Setup and Initial Challenges
I started by installing the Hubitat Elevation hub and connecting it to my network. My collection of Zemismart switches, including single, double, and triple gang models, were all in working order on SmartThings. However, moving them to Hubitat wasn’t as straightforward as I hoped. I quickly realized that simply adding the devices wasn’t enough; I needed the right drivers to ensure they functioned properly.
Finding the Right Drivers
I spent a considerable amount of time researching the best drivers for my setup. The Hubitat community was incredibly helpful, pointing me towards several options:
- Nue Sigbee Switch
- Generic Zigbee Switch
- Generic Zigbee Multi-Endpoint Switch
- Zemismart Zigbee Wall Switch Multi-Gang (a custom driver shared by a community member)
Initially, I faced issues where all switches on a multi-gang device were treated as a single entity. This meant I couldn’t control each switch individually, which was a significant drawback. After some trial and error, I discovered that the custom driver provided by the community was the key to unlocking the full functionality of my multi-gang switches.
Overcoming Obstacles
One of the hurdles I encountered was the lack of child devices in the device list. This made it difficult to assign specific functions to each switch. However, with the custom driver, I was able to configure each switch independently, ensuring that they operated as intended. It was a bit of a learning curve, but the satisfaction of seeing everything work seamlessly made it all worthwhile.
Tips for a Smooth Migration
If you’re planning a similar migration, here are some tips to keep in mind:
- Research Drivers Thoroughly: Spend time finding the right drivers for your devices. The Hubitat community forums are an invaluable resource.
- Backup Your Configurations: Before making any changes, ensure you have backups of your current setup. This will save you time in case something goes wrong.
- Leverage Custom Drivers: Don’t hesitate to use custom drivers shared by the community. They often provide the functionality needed for specific devices.
- Take It Step by Step: Migrating devices one at a time can help you identify and resolve issues more efficiently.
Migrating to Hubitat has been a transformative experience. The flexibility and power of the platform, combined with the support from the community, have made it possible to create a seamless and efficient smart home setup. If you’re considering making the switch, I highly recommend exploring the possibilities that Hubitat offers. It’s a community-driven ecosystem that truly puts the user in control.
A huge thank you to everyone in the Hubitat community who shared their knowledge and expertise. Your contributions make projects like mine possible!
Happy automating!
