Successfully Mounting Wyze Cam Pan V3 with Command Strips
I recently faced the challenge of mounting my Wyze Cam Pan V3 without drilling holes in my walls. After some research, I discovered that using command strips was a viable solution. Here’s how I made it work!
First, I measured the exact spot where I wanted to place the camera. I made sure it had a clear view of the area I wanted to monitor. Then, I carefully applied the command strips to the wall, ensuring they were evenly spaced and aligned perfectly. I was a bit nervous about the stability, but the camera held up surprisingly well.
One thing I learned is to use heavier-duty command strips if possible, as they provide better support. I also found that placing the camera slightly lower than I initially thought gave me a better angle. The setup process was straightforward, and the camera functions just as smoothly as it did when it was on a tripod.
This experience taught me that sometimes, creative solutions can work just as well as traditional methods. I’m now confident in using command strips for other devices around my home. If you’re in a similar situation, give it a try—it might just save you the hassle of drilling holes!
Tip #1: Use heavier-duty command strips for better support.
Tip #2: Experiment with placement to find the perfect angle.
