I’ve been struggling with getting my Intermatic CA9000 motion sensors to pair correctly with my Vera system. After weeks of trial and error, I stumbled upon a solution that I thought I should share with the community.
The key was realizing that the pairing process requires a quick double press of the grey button on the sensor. This simple action ensures the sensor pairs correctly, avoiding the frustration of incorrect pairing and rapid battery drain.
Additionally, if you ever need to reconfigure the sensor or repair the connection, a quick double press of the grey button allows the Vera to communicate effectively with the sensor. I’ve tested this method on Vera UI4.0, and it works like a charm!
If anyone else has been struggling with these sensors, I hope this tip helps you avoid the same headaches. It’s always great to find a solution and share it with others who might be facing the same issue. Happy pairing! ![]()
