Successfully Pairing Somfy Blinds with Composio Remote
After struggling for weeks to pair my Somfy blinds with the Composio remote, I finally found a solution! It turns out the issue was with the Composio not sending specific commands to individual blinds. Here’s what worked for me:
  1. Identify the Problem: The Composio remote wasn’t addressing specific blinds, so the RFXtrx receiver wasn’t picking up the signals.
  2. Solution: I used the Composio RTS instructions and paired each blind individually. This involved pressing the programming button on the Composio and ensuring it sent the correct signal to each blind.
  3. Outcome: Now, all my Somfy blinds are successfully paired with the RFXtrx, and I can control them seamlessly through my home automation system.
This was a bit of a learning curve, but it’s so rewarding to have everything working now! If anyone else is struggling with similar issues, I highly recommend checking the pairing instructions carefully and ensuring each device is addressed individually.
