Successfully Replacing a Faulty Z-Wave Device
I recently encountered an issue with my Aeon Smart Siren, which had been functioning well but developed a persistent humming noise. After some research, I discovered that replacing the faulty device with a newer, quieter model was the solution. However, I faced a challenge when SmartThings indicated that the device wasn’t considered failed, preventing me from proceeding with the replacement.
After some troubleshooting and reaching out to the community, I found that manually excluding the device from the Z-Wave network and then re-adding the new one resolved the issue. This process involved resetting the faulty device and ensuring it was no longer recognized by the hub before pairing the new siren.
Here’s a quick tip for anyone facing similar issues: Always check the device’s status in your hub’s settings and consider manual exclusion if automatic replacement doesn’t work. It’s a bit of a hassle, but it ensures a seamless transition to the newer, improved device.
If you’ve had success with similar fixes or have other tips for troubleshooting Z-Wave devices, I’d love to hear about them! Let’s keep sharing our experiences to help each other out. :blush:
