I recently encountered an issue with my Cam Pan Pro after moving it to a new network. The setup process was smooth, but my phone app didn’t display a QR code, which was puzzling. I had two main concerns: how to reset the Cam Pan Pro, especially since its base swivels when pressing the setup button, making it hard to keep the button pressed for more than a second or two, and whether resetting the device would prompt the phone app to show a QR code.
After some trial and error, I found a solution. Initially, I tried pressing the button but couldn’t hold it long enough due to the swiveling base. However, I discovered that if I let the power cord swing freely while pressing the button, it would stop the base from moving. This allowed me to press the button for about 10 seconds, which successfully reset the device. Once reset, the app displayed a new QR code, and everything started working perfectly again.
This experience taught me the importance of persistence and creativity when troubleshooting. If you’re facing similar issues, don’t hesitate to try different approaches—sometimes a simple adjustment can make all the difference. I’m now up and running smoothly, and I hope this guide helps others who might be stuck in a similar situation.
