Successfully Resetting Stored Data in OpenHAB MySQL
I recently encountered an issue with my OpenHAB setup where I accidentally set a wrong value for a maxGraphValue item, causing my chart to display incorrectly. After some research, I managed to resolve the problem by purging the stored data from the MySQL database. Here’s how I did it:
  1. Accessing the Database: I used phpMyAdmin on my NAS to connect to the OpenHAB MySQL database. This tool provided a user-friendly interface to explore and manage the database tables.
  2. Identifying the Relevant Tables: I discovered that each item in OpenHAB corresponds to specific tables in the database. The tricky part was mapping the item names to the correct table numbers. Through some trial and error, I found that the tables for my items were within a specific range.
  3. Deleting the Data: Once I identified the correct table for maxGraphValue, I executed a SQL command to delete all entries from that table. This effectively reset the stored data, allowing the chart to display correctly again.
  4. Post-Reset Verification: After purging the data, I monitored the system to ensure that new data was being collected and displayed accurately. It was a relief to see the chart functioning as intended.
This experience taught me the importance of understanding how data is stored and managed in OpenHAB. It also highlighted the value of tools like phpMyAdmin for database management. If you’re facing similar issues, don’t hesitate to explore your database and don’t be afraid to ask for help in the community!
Happy tinkering! :rocket:
