Hey everyone, I wanted to share my experience with setting up a floodlight automation, which was a bit of a challenge but ultimately a great learning experience. Hopefully, this can help others who might be facing similar issues. The Goal: I wanted my floodlight to turn on at sunset plus a few minutes and then turn off after a set time. Additionally, I wanted it to reactivate if motion was detected after it had turned off. Sounds straightforward, right? But as I soon discovered, it wasn’t without its hurdles. The Problem: I programmed two separate rules—one for turning the floodlight on and another for turning it off. The idea was that after the scheduled off time, motion would trigger it back on. However, no matter how I tweaked the settings, the floodlight wouldn’t reactivate after the initial off time. It was frustrating, to say the least. The Journey: I spent hours reprogramming, checking logs, and even reaching out to the community for advice. One common suggestion was to ensure that the floodlight was in the correct mode when the motion was detected. After some research, I realized that the issue might be with how the automation was structured. The floodlight was defaulting to a mode where it couldn’t be triggered by motion once it had turned off. The Solution: After some trial and error, I simplified the setup. Instead of two separate rules, I combined them into one comprehensive rule. This way, the floodlight would activate at sunset, stay on for the set duration, and then reactivate if motion was detected. The key was ensuring that the automation didn’t conflict with the floodlight’s operational mode. What I Learned: - Simplify First: Before diving into complex setups, start simple and build from there. - Check Modes and States: Ensure that devices are in the correct operational mode for your automations to work seamlessly. - Community Support: Don’t hesitate to reach out to forums. Sometimes, a fresh pair of eyes can spot what you’ve missed. Final Thoughts: While it was a bit of a journey, resolving this issue gave me a deeper understanding of how automations work and the importance of thorough testing. It’s a reminder that even the most frustrating problems can be solved with patience and persistence. If anyone else is struggling with similar issues, feel free to reach out. I’m happy to share what I’ve learned! Cheers, [Your Name]
