Recently, I encountered a frustrating issue where my HomeAssistant setup would freeze after approximately 20 hours of connecting a Zigbee Gateway USB Stick. This was perplexing, especially since I had previously used a different USB Stick from IT-Stuff without any issues. After that one broke, I decided to invest in a more robust option, trying both the Sonoff Zigbee Dongle Plus and the Conbee 2. Unfortunately, both resulted in the same freezing problem, which was disheartening.I started by checking the logs, but the HomeAssistant logs didn’t reveal anything useful. Suspecting a firmware issue, I updated both the Sonoff and Conbee 2 devices, but the problem persisted. I also considered the possibility of a Supervisor OS update, but even after updating, the issue remained.Determined to resolve this, I decided to test the latest HomeAssistant Core Version, 2023.10.1. To my relief, the freezing issue disappeared with this update. It seems that the problem was related to a bug in the earlier versions of HomeAssistant, which has now been addressed.For anyone else experiencing similar issues, I recommend the following steps:- Ensure your HomeAssistant is running the latest version.- Check for and install any firmware updates for your Zigbee Gateway.- If the issue persists, consider testing with a different USB Stick or gateway.This experience taught me the importance of keeping software up-to-date and not hesitating to try alternative hardware if issues arise. It’s also a reminder of the resilience and adaptability required in the world of smart home technology.I hope this experience helps others troubleshoot similar issues and emphasizes the value of perseverance in problem-solving within the HomeAssistant community.
