I recently embarked on installing OpenHAB on my Raspberry Pi 3B, and I must say, the journey has been both exciting and a bit challenging. After setting up the SD card using the latest GitHub image and Etcher, I went through the initial configuration via SSH using the openhabian-config tool. Everything seemed to be in order—the HTTP checks worked fine, and the system updates went smoothly. However, the real test came when I decided to upgrade to the snapshot version to access the latest features.
The upgrade process itself was uneventful, but upon rebooting, I encountered an HTTP 404 error when trying to access the web interface. This was perplexing because I had successfully done similar upgrades in the past without any issues. I retried the upgrade multiple times, even switching to milestone versions, but the problem persisted. I started to wonder if there was something I was missing or if there had been any recent changes in the upgrade process that I wasn’t aware of.
After some research and reaching out to the community, I discovered that the issue might be related to the SSL certificate configuration. I had recently enabled SSL for enhanced security, but it seemed that the certificate wasn’t being recognized correctly after the upgrade. This was a bit frustrating, especially since the web browser could still access the interface without issues, but the mobile app was having trouble connecting.
Determined to resolve the issue, I decided to dive deeper into the configuration files. I found that the base_url setting in the configuration.yaml file needed to be explicitly set to use the HTTPS protocol. Once I made that change and rebooted the system, the HTTP 404 error disappeared, and everything started working as expected again.
This experience taught me the importance of carefully reviewing configuration settings, especially after major updates. It also highlighted the value of community support—without the insights shared by others who had encountered similar issues, I might still be troubleshooting this problem. I’m now fully up and running with the latest OpenHAB features, and it’s been a great learning experience!
If anyone else is facing similar issues, I’d recommend checking your SSL certificate paths and ensuring that all URLs in your configuration files are correctly formatted. Happy automating!
