Successfully Resolving SmartThings Presence Detection Issues with SharpTools
Hey everyone, I wanted to share my experience with resolving a presence detection issue I was having with SmartThings. It all started when I noticed that my phone wasn’t consistently updating my presence status, especially when arriving or leaving home. This was causing some frustration as my smart home routines weren’t triggering as expected.
After some research, I came across @joshua_lyon’s SharpTools, which seemed like the perfect solution. I followed the example setup on his site, but I still encountered some issues where the presence updates would fail, particularly when my phone was switching between 4G and Wi-Fi. This was quite perplexing and a bit frustrating, as I really wanted this feature to work seamlessly.
I decided to dig deeper and experiment with the settings. I discovered that the main issue was related to the timing of the presence detection and the handoff between cellular and Wi-Fi networks. To tackle this, I added retry logic to my Tasker task. Now, the task attempts to update my presence status up to 10 times before giving up. This has significantly reduced the number of failed attempts and made the system much more reliable.
Here’s a quick breakdown of what I did:
  • Retry Logic: I set the task to retry up to 10 times if the initial attempt fails. This ensures that even if the first few attempts are unsuccessful due to network issues, there’s a good chance of success later on.
  • Timeout Adjustments: I played around with the timeout values to make sure they were appropriate for my setup. This helped prevent the task from failing prematurely.
  • Error Handling: I made sure that the task continues even if it encounters an error, allowing it to retry without interruption.
I also found that keeping a ‘Permanent’ notification running in the background was helpful. It lets me know when the task is active and gives me peace of mind that the process is working as intended.
This solution has been a game-changer for me. My presence detection is now much more reliable, and my smart home routines are triggering consistently. I’m really happy with how this turned out and would recommend SharpTools to anyone looking to enhance their SmartThings setup.
If anyone else has had similar issues or wants to implement this themselves, feel free to reach out! I’d be happy to share more details or help troubleshoot any problems you might encounter. Happy automating! :rocket:
