Recently, I encountered an issue with my Z-Wave nodes after switching from Domoticz to Home Assistant and upgrading my Aeotec stick. Several nodes lost their node numbers, displaying ‘undefined:undefined’ in the system. This was frustrating as their associated entities were still present but showed errors. I want to share my journey and solution in case others face a similar problem.
The Problem
After restarting Home Assistant, a few of my Z-Wave nodes lost their node numbers. This meant I couldn’t control them through my smart home setup, even though the devices were still physically present and functional. The error message was perplexing, and I wasn’t sure how to restore the node numbers.
Initial Attempts
I tried restarting Home Assistant multiple times, hoping it would reset the node numbers. Unfortunately, this didn’t work. I also checked if there were any updates or patches available for my Aeotec stick, but nothing seemed to address the issue directly.
The Solution
After some research, I discovered that sometimes Z-Wave nodes can get into an inconsistent state, especially after a system migration or hardware upgrade. To resolve this, I needed to perform a Z-Wave network heal. Here’s how I did it:
Enter Z-Wave Configuration Mode:
- I accessed the Z-Wave settings in Home Assistant.
- I initiated the network healing process, which instructs the controller to re-interview all nodes.
Re-interview Nodes:
- The healing process prompted each node to send its information again to the controller.
- This included re-establishing node numbers and ensuring all devices were recognized correctly.
Verify Node Numbers:
- After the healing process completed, I checked the node numbers again.
- Thankfully, all nodes had their correct numbers restored, and the devices were functional once more.
Key Learnings
- Regular Maintenance: Periodically performing a Z-Wave network heal can prevent such issues from arising.
- Understanding Z-Wave: Familiarizing myself with Z-Wave commands and processes was crucial in troubleshooting and resolving the problem.
- Community Support: If I had been stuck, reaching out to the Home Assistant or Z-Wave communities would have been a great next step.
Conclusion
While encountering lost Z-Wave node numbers was initially daunting, methodically addressing the issue and leveraging available tools resolved the problem. This experience reinforced the importance of understanding my smart home setup and the value of proactive maintenance. If anyone else faces a similar issue, I hope this guide helps you restore your nodes and get back to enjoying your smart home setup!
Happy automating! ![]()
