Hi everyone,
I wanted to share my recent success in setting up a rain sensor for my Home Assistant setup. I’ve been looking for a reliable way to automatically close my awning and send a notification if any of my windows are open during a rainstorm. After some research and trial and error, I found a solution that works perfectly!
First, I started by searching for a rain sensor that integrates well with Home Assistant. Unfortunately, most of the options I found were either DIY solutions or didn’t meet my specific needs. However, I discovered that using an Aqara door sensor as a DIY rain sensor was a viable option. Here’s how I set it up:
DIY Rain Sensor Setup: I placed an Aqara door sensor near my awning. The sensor detects rain by using its built-in motion and contact sensors. When it detects rain, it triggers a series of actions in Home Assistant.
Automations in Home Assistant: I created an automation in Home Assistant that does the following:
- Closes the awning if it’s open.
- Checks if any of my windows (also using Aqara door sensors) are open.
- Sends a Telegram message if any windows are open, alerting me to close them.
Here’s a quick look at the automation setup:
yaml
- id: ‘123456789’
alias: Rain Sensor Automation
trigger:- platform: state
entity_id: binary_sensor.rain_sensor
to: ‘on’
condition:
action: - service: cover.close
entity_id: cover.awning - service: notify.send_telegram
data:
message: “Rain detected! Please close the windows.” - service: automation.turn_on
entity_id: automation.check_windows
- platform: state
- Testing and Fine-Tuning: After setting up the automation, I tested it by manually triggering the rain sensor. Everything worked as expected—the awning closed, and I received a notification. I also tested it during a light rain shower, and it worked perfectly!
I’m really happy with how this setup turned out. It’s a simple yet effective solution that integrates seamlessly with my existing Home Assistant ecosystem. If anyone has questions or needs help setting up something similar, feel free to ask!
Cheers,
Timo
