Hey everyone, I wanted to share my recent experience setting up a RESTful sensor to monitor my local train system. It was a bit of a learning curve, but I managed to get it working smoothly! Here’s how it all went down.
Initially, I was following the example code from the Home Assistant website to set up a simple REST sensor. The goal was to pull in some real-time data from the train system, but I kept running into an error: ‘Error rendering template: UndefinedError: ‘value_json’ is Undefined’. At first, I was a bit stumped. I double-checked my configuration, made sure the URL was correct, and even tried different payloads, but nothing seemed to work.
After some research and a bit of trial and error, I realized that the issue might be with how I was handling the response data. I decided to break down the problem step by step. First, I tested the endpoint directly in my browser to ensure it was returning the expected JSON data. Once I confirmed that, I moved on to checking the response headers and content type in Home Assistant. It turns out I needed to specify the correct content type in the sensor configuration to ensure Home Assistant could parse the JSON response properly.
Here’s the corrected configuration that finally worked for me:
yaml
sensor:
- platform: rest
resource: http://api.train-system.com/realtime
name: Train System Status
value_template: ‘{{ value_json.status }}’
scan_interval: 60
By adding the value_template and ensuring the response was properly formatted, I was able to get the sensor up and running. It’s now pulling in the train statuses in real-time, which is super handy for planning my commute!
This experience taught me the importance of thoroughly testing each component of a setup. Sometimes, it’s the small details like response headers or data parsing that can trip you up. I also learned that breaking down the problem into smaller parts can make troubleshooting much more manageable.
If anyone else is working on a similar project or running into issues with REST sensors, feel free to reach out! I’m happy to share what I’ve learned and help troubleshoot any issues you might encounter. Happy coding and happy automating! ![]()
