Hi everyone, I’m relatively new to the world of home automation and have been experimenting with Homematic components over the past few weeks. I wanted to share my experience in setting up my CCU to send an email notification when my garage door remains open for more than 15 minutes. I hope this helps anyone else who might be tackling a similar project!
Initially, I thought this would be a straightforward task. After all, the idea was simple: monitor the garage door status and trigger an email if it stays open beyond a certain timeframe. I started by using the built-in door contact sensor to detect when the garage door was open or closed. The email functionality worked when I tested it, but there was a catch—it sent the email immediately when the door opened, not after the 15-minute delay I intended.
This was a bit frustrating. I scoured the forums and documentation, and while I found some solutions involving external services like Home Assistant, I was determined to make it work directly through the CCU without additional software. I realized I needed to create a more sophisticated rule that could track the duration the door remained open.
After some trial and error, I figured out how to structure the rule. I used the CCU’s built-in timer function to start counting once the door opened. The rule checks the door’s status every minute. If it’s still open after 15 minutes, the email is triggered. This approach worked perfectly!
Here’s a quick breakdown of the steps I took:
- Set Up the Door Contact Sensor: I configured the door contact sensor to report its status to the CCU.
- Create a Rule for Door Opening: I programmed the CCU to start a timer when the door opens.
- Implement a Delayed Email Notification: The rule checks the door’s status every minute. If it remains open after 15 minutes, the CCU sends an email.
- Test the System: I tested the setup by opening the garage door and waiting to see if the email was sent after the delay.
This project gave me a great sense of accomplishment, and it’s been a reliable system for monitoring my garage door. It’s also taught me the value of persistence and the importance of understanding the tools I’m working with. I’m now more confident in tackling other automation projects around my home!
If anyone has questions or needs help with similar setups, feel free to reach out. I’m happy to share what I’ve learned!
Best regards,
