Hi everyone, I wanted to share my recent success in setting up MQTT automation with my Hubitat system. After some trial and error, I managed to integrate my Raspberry Pi as an MQTT broker and connect it to Hubitat to trigger rules. Here’s how I did it:
Setting Up the Raspberry Pi: I started by installing MQTT on my Raspberry Pi. It was a breeze using the command line, and I set it up as a local broker. This allowed me to communicate with my devices without relying on external services.
Connecting to Hubitat: The next step was configuring Hubitat to interact with MQTT. I used the MQTT integration in Hubitat to subscribe to topics and publish messages. This part was a bit tricky, but with some research and testing, I got it working smoothly.
Creating Rules: I then moved on to creating rules in Hubitat. For example, I set up a rule where pressing a button on my Tasmota-flashed wall switch would trigger an MQTT message, which in turn would activate a scene in Hubitat. It’s amazing how versatile this setup is!
Testing and Tweaking: I spent some time testing each component to ensure everything worked as expected. It was satisfying to see the system respond correctly to my commands. I also made a few adjustments to optimize performance, such as refining the trigger conditions and response times.
The end result is a seamless and efficient automation system that integrates perfectly with my existing setup. I’m now able to control multiple devices with just a few taps, and the possibilities for future expansions are endless.
If anyone has questions or needs help setting up something similar, feel free to reach out! I’d be happy to share more details or troubleshoot any issues you might encounter. Happy automating! ![]()
