Hey everyone! I wanted to share my experience setting up RGB dimming using Node-RED and Z2M. It was a bit of a journey, but I finally got it working smoothly. Here’s how I did it:
Problem Encountered:
I had a working flow for dimming two years ago, but after some updates, it stopped functioning. The issue seemed to stem from changes in either Z2M or Node-RED, which threw me off track for a while.
**What I Tried:**1. Reviewing the Flow: I started by examining my existing Node-RED flow. The initial setup involved getting the current state of the kitchen lights and adjusting the brightness based on button presses.
2. Adjusting Brightness Logic: I realized the brightness adjustment wasn’t smooth. So, I tweaked the function node to increment the brightness by 50 each time, capping it at 255 to prevent overstepping.
3. Testing and Iterating: After making these changes, I tested the flow repeatedly. Each test gave me insights into what was working and what wasn’t, allowing me to refine the logic further.
4. Seeking Community Help: When I hit a wall, I turned to the community forums. Someone suggested checking the entity IDs and ensuring they were correctly referenced in the service calls. That was the missing piece!
Solution:
By ensuring the entity IDs were accurate and adjusting the brightness increment logic, the flow now works perfectly. The lights dim smoothly with each button press, and the RGB settings are preserved throughout the process.
Lessons Learned:- Always double-check entity IDs after updates or changes.
- Incremental adjustments in brightness provide a better user experience.
- The community is a goldmine for troubleshooting tips!
If anyone else is struggling with similar issues, feel free to reach out. I’m happy to help walk through the setup or troubleshoot any hiccups you encounter. Happy automating! ![]()
