Hey everyone, I just wanted to share my experience setting up the Shelly Plus 2PM to control my garage roller door. I’ve been exploring the world of smart home automation, and this project was a great learning curve for me.
Initially, I was a bit overwhelmed by the setup process. I had to configure the relay protection settings, which involved accessing the device’s web interface at http://YOUR_IP_ADDRESS/#/switch/0/settings/protections and http://YOUR_IP_ADDRESS/#/switch/1/settings/protections. I had to ensure that Relay 0 and Relay 1 couldn’t be active simultaneously, which was a crucial step to prevent any potential electrical issues.
The web button interface was a bit tricky at first. I had to map Button 0 to control the opening and closing of the roller door via Relay 0 or Relay 1, and Button 1 was set up as an emergency stop with interlock functionality. It took some trial and error, but once everything was configured correctly, the system worked seamlessly.
One thing I found particularly helpful was the Shelly 2.5 roller shutter setup. The documentation provided by Shelly was comprehensive, making it easier to transition from the default Relay mode to the Roller Shutter mode. This feature allowed me to automate the opening and closing of my garage door with precision.
I also discovered that the Shelly 2.5 can operate in two distinct modes: Relay and Roller Shutter. Initially, the device is set to Relay mode, but switching to Roller Shutter mode via the /settings endpoint was straightforward. This flexibility is a huge plus for users looking to customize their smart home setups.
Overall, the process was a mix of challenges and triumphs. I learned the importance of carefully following setup guides and not being afraid to experiment. If anyone else is looking to automate their garage door, I highly recommend the Shelly Plus 2PM. It’s a reliable device that has significantly enhanced my home automation journey.
