I recently got my hands on the Philio Smart Color Button PSR04 and wanted to share my experience setting it up and integrating it into my smart home ecosystem. This device has been a game-changer for me, especially when combined with rule-making apps like CoRE or Rule Machine. Here’s how I got it up and running smoothly!
Setup Process
- Installation: I followed the standard inclusion process for Z-Wave devices. The setup was straightforward, and the button was recognized by my hub without any issues.
- Device Handler: I used the custom device handler available on GitHub. It added the necessary capabilities like detecting button presses and dimming levels. The installation process was smooth, and the handler worked right out of the box.
Integration and Usage
I primarily use this button as a wall dimmer for my living room lights. With CoRE, I programmed it to adjust the brightness of my lights based on the dimming level set on the button. It’s incredibly responsive and has made my evenings much more comfortable!
Tips and Tricks
- Dimming Mode: The dimming mode works perfectly for adjusting light levels. I love how it provides a seamless experience, almost like having a traditional wall dimmer.
- Button Holds: While the current handler doesn’t support detecting button holds, I’m excited about the possibility of future updates adding this feature. It would open up even more automation possibilities!
- Silencing the Beep: The beep can be a bit annoying, so I’m hoping the developer adds an option to turn it off in future updates.
Common Issues and Solutions
- Initialization of Slider Values: I faced a minor issue where the slider for the secondary function (like adjusting lamellas on a venetian blind) didn’t initialize correctly. However, I found that manually setting the value once and then letting the automation take over worked as a temporary fix.
- Compatibility: Ensure your hub supports the latest Z-Wave firmware for optimal performance. I also recommend checking the device handler regularly for updates.
Questions for the Community
- Has anyone successfully integrated this button into a more complex automation setup? I’d love to hear about creative uses!
- Are there any workarounds for detecting button holds without waiting for the official update?
This device has been a fantastic addition to my smart home, and I’m eager to see how it evolves with future updates. If you’re looking for a versatile and reliable button controller, I highly recommend giving the Philio Smart Color Button PSR04 a try!
Happy automating! ![]()
