Successfully Solving Wyze Bulb Reset Issues
Hey everyone! I wanted to share my experience with the Wyze bulbs resetting issue, which I’ve been dealing with for a while now. It was really frustrating because the bulbs would reset intermittently, especially on my sunrise and sunset schedule. I didn’t have any kids or pets messing with the switch, so it was puzzling why this was happening.After some research and trial and error, I found a solution that worked for me. I discovered that the bulbs have a feature where they reset when switched three times in rapid succession. While this is a handy feature for programming, it was causing issues for me. I decided to adjust the settings on my smart switch to disable this feature. I also made sure to update the firmware on both the bulbs and the switch, as outdated firmware can sometimes cause unexpected behavior. After these changes, the bulbs have been working perfectly without any resets. It’s such a relief to finally have a smooth experience with my smart lighting setup!If anyone else is struggling with this issue, I highly recommend checking your switch settings and ensuring all firmware is up to date. It’s amazing how a few tweaks can make such a big difference. Happy smart home tinkering! :rocket:
