Hey everyone, I wanted to share my recent success in synchronizing the time on my MySensors network using OpenHAB. It was a bit of a challenge, but I managed to figure it out and thought I’d document the process in case anyone else is tackling the same issue.
First, I set up a rule in OpenHAB to respond to time requests from my sensors. The key was understanding how to convert the Unix timestamp into the correct timezone, including daylight saving time adjustments. I stumbled a bit at first, but after some research and trial and error, I got it working!
Here’s a quick rundown of what I did:
- Identify the Trigger: I set up a trigger to respond to MQTT requests from the sensors asking for the current time.
- Calculate the Timestamp: Using the
nowfunction, I captured the current time in milliseconds, which gives me the Unix Epoch in UTC. - Adjust for Timezone: The tricky part was converting this UTC timestamp into my local timezone. I found that using
java.util.Dateandjava.util.TimeZoneallowed me to handle the conversion accurately, even during daylight saving time changes. - Send the Response: Once the timestamp was correctly adjusted, I sent it back to the sensor via MQTT.
This setup has been running smoothly for a few weeks now, and it’s been a huge help in keeping all my sensors in sync. It’s such a relief to have this working without any hiccups!
If anyone has questions or needs help setting something similar up, feel free to reach out. I’d be happy to share my rule configurations or troubleshoot any issues you might encounter. Happy tinkering! ![]()
