Hey everyone, I wanted to share my journey and solution to a problem I encountered with my smart home setup. I recently created a switch template in Home Assistant (HA) to control some devices, and while it worked perfectly within HA, I noticed an issue when integrating it with HomeKit. Specifically, the switch would turn on as intended but wouldn’t automatically turn off again in HomeKit, unlike in HA. This was a bit frustrating, but I decided to dive in and figure it out!
After some research and trial and error, I realized that the issue was related to how HomeKit checks the state of the switch. I needed to ensure that the switch template in HA communicated its state changes effectively to HomeKit. I started tweaking the configuration, adding some additional commands and even experimenting with input booleans to track the switch state more accurately.
Here’s what I learned: By incorporating input booleans and adjusting the turn_on and turn_off actions in the switch template, I was able to get the switch to behave consistently across both HA and HomeKit. The key was ensuring that the state changes were properly communicated and that HomeKit received the necessary updates to reflect the current status of the switch.
I also added some extra steps to keep the Harmony remote activity in sync after the fix, which was a nice bonus. The updated configuration now includes additional services to handle the state changes more robustly, ensuring that everything works seamlessly together.
I hope this helps someone else who might be facing a similar issue. It’s always satisfying to solve a problem and see everything working as intended! If anyone has further questions or suggestions, feel free to reach out. Happy smart home tinkering! ![]()
