Hey everyone! I wanted to share my recent experience with syncing two FGRGBW442 devices. At first, I was a bit puzzled because the second association group wasn’t working as expected. I kept trying different methods, but nothing seemed to click. Frustration set in, but I knew I couldn’t give up!After some research and trial and error, I discovered that the key was ensuring both devices were on the same network and that the association process was initiated correctly. Here’s what worked for me:1. Reset Both Devices: Make sure both devices are in factory reset mode. This ensures a clean slate for the association process.2. Start the Association Process: Initiate the process on the primary device. Wait for the LED to indicate it’s ready to receive the secondary device.3. Add the Second Device: Quickly place the second device into association mode. The LED should change, confirming the connection.4. Test the Sync: Once both devices are paired, test them by adjusting settings on one to see if they reflect on the other.The relief was immense when both devices finally synced seamlessly! It was a great reminder that persistence pays off. I hope this helps anyone else struggling with the same issue. Happy syncing! ![]()
