Hi everyone! I wanted to share an exciting project I recently completed. After struggling with frequent battery changes for my sensors, I decided to explore a more sustainable solution. I came across a small device that converts 4-12V DC to 3.3V DC, which is perfect for my sensors. Here’s how I made it work:
Conversion Process: I hooked up a few wires to the power module and connected it to a USB cable. This allowed me to power my sensors directly from a USB port, eliminating the need for batteries.
Installation: I drilled a small hole in the sensor to run the wire and placed the power module inside where the battery would normally go. This was a bit tricky, but worth it for the convenience.
Testing: I tested the setup in my attic, and it worked like a charm! The power module even has an LED indicator, so I can easily see if it’s powered on.
Flexibility: I designed the setup so it can be easily reverted back to battery power if needed. This gives me peace of mind knowing I can switch back if necessary.
This project has been a game-changer for me. No more battery changes, and I’m contributing to a more sustainable setup. I plan to do this for a few more sensors around my home. If anyone is interested in the components I used, I’d be happy to share the details!
Thanks to everyone in the community for the inspiration and support. It’s amazing how a little creativity can solve such a common problem!
