Hey everyone, I wanted to share my recent experience with the auto-entities card in Home Assistant. It was quite the journey, but I managed to figure it out, and I thought it might help someone else facing a similar issue.
A few days ago, I noticed that one of my auto-entities cards stopped displaying the full list of entities. Instead, it only showed the header. At first, I was a bit puzzled. I hadn’t made any changes to the card’s configuration, so I wasn’t sure what had gone wrong. I decided to dive into the problem and see if I could find a solution.
First, I checked the card’s configuration in the YAML editor. Everything looked correct, but I decided to test it by adding a new entity to the list. The new entity didn’t appear, which confirmed that the issue was with the card itself rather than a specific entity. I then looked into the community forums and discovered that others had encountered similar problems, often related to updates in Home Assistant or changes in entity availability.
After some research, I found a suggestion to clear the card’s cache or force a refresh. I tried this by restarting Home Assistant, but the issue persisted. Determined to solve the problem, I decided to recreate the card from scratch, carefully following the documentation to ensure there were no syntax errors. To my relief, the new card worked perfectly, displaying all the entities as intended.
Reflecting on this experience, I realized the importance of thorough documentation and the value of community support. If it hadn’t been for the tips I found in the forums, I might still be struggling with the issue. It’s a great reminder of how helpful and supportive the Home Assistant community can be.
I hope this little story helps anyone else who might be facing a similar issue with their auto-entities card. Remember, sometimes starting fresh can make all the difference! Happy automating everyone! ![]()
