Successfully Troubleshooting Zooz Zen32 Scene Controller Issues
I recently encountered some puzzling behavior with my Zooz Zen32 scene controller, and I thought I’d share my journey to resolving it. Hopefully, this can help others who might be facing similar issues!
The Problem:
I configured the Zen32 to control different light groups using various events (KeyPressed, KeyPressednx, KeyHeldDown, KeyReleased). While KeyPressed events worked seamlessly for all buttons, I noticed some inconsistencies with KeyHeldDown and KeyReleased events. Specifically, on Button 1, the KeyPressed event fired while holding the button, and on Button 2, the KeyPressed event triggered when the button was released instead of KeyReleased. Both buttons were set to turn off specific light groups, which added to the confusion.
The Investigation:
Initially, I suspected the issue might be related to how the lights were configured or perhaps a broader Home Assistant (HA) problem, as Zooz support pointed me in that direction. I reviewed my configuration files and even reached out to the HA community to see if others had encountered similar issues. Interestingly, I found a few older threads where users reported similar problems, but they hadn’t been resolved or followed up on.
The Solution:
After some trial and error, I discovered that the issue wasn’t with the lights themselves but rather with how the events were being processed by HA. I adjusted the event triggers in my automations to ensure they were correctly mapped to the intended actions. For instance, I made sure that KeyHeldDown events were only tied to the actions I wanted them to perform and that KeyReleased events were properly configured on Button 2.
Key Takeaways:
  1. Configuration Precision: Double-check your event triggers and ensure they’re correctly mapped to their intended actions.
  2. Community Support: Don’t hesitate to reach out to forums or communities. Even if older threads don’t have a resolution, they can provide valuable insights or confirm that others are facing similar issues.
  3. Testing and Iteration: Be patient and methodical in testing different configurations. Sometimes, the solution is as simple as adjusting how events are processed.
Final Thoughts:
While troubleshooting this issue was a bit of a head-scratcher at first, it turned into a valuable learning experience. I now have a better understanding of how event triggers work within HA and feel more confident in configuring my smart home devices. If anyone else is facing similar issues, please don’t hesitate to reach out—I’d be happy to help!
Happy automating! :rocket:
