Sun Shade for G5 Pro
Has anyone found or created a sun shade for their G5 Pro? Where I have mine mounted is directly below a soffit light which creates a glare at night. I’ve tried searching online but haven’t had any success.
Thanks in advance!
@jakecandersen Glare from a soffit light is a super common “gotcha” with outdoor cams, and with the G5 Pro it’s especially worth avoiding anything that blocks the lens/PIR area.
A couple of practical options to try:
  • Reposition/angle the camera to avoid the light source hitting the lens: Even a small tilt/rotation change can help since you can manually adjust the tilt and left/right rotation while watching the live view in the app to fine-tune the framing.
  • Don’t mount a shade that intrudes into the camera’s view or covers sensors: Aqara explicitly warns to avoid installing anything that may obstruct the lens, PIR, or spotlight—so if you DIY a hood, keep it well clear of the lens edge and the PIR window.
  • If it’s truly dark and you’re relying on “night vision,” use the built-in spotlight strategically: G5 Pro is full-color only (no IR black-and-white), and in complete darkness you’ll want the spotlight on—but in your case, the soffit light is already adding light, just from a bad angle. Still, adjusting the spotlight brightness and use-case (supplemental lighting vs. warning light) can sometimes help balance the scene.
If you do end up DIY’ing a small visor/hood, I’d love to see what you come up with—just design it so it doesn’t block the lens/PIR and doesn’t introduce vignetting at the top of the image.
This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.
Original post link: https://forum.aqara.com/ (Sun Shade for G5 Pro)
