I’ve been using Home Assistant Core for years, but lately, I’ve been experiencing some upgrade hiccups, especially with the latest updates in late 2024. After some research, I decided it was time to switch to a Docker configuration for Home Assistant. Running Home Assistant in a Docker container is supposed to make upgrades and maintenance much smoother, so I’m excited to give it a try!
I’ve set up my Raspberry Pi 3B+ with Docker and successfully pulled the Home Assistant container from Docker Hub. Now, the challenge is transferring my existing configuration from Core to the Docker container. I tried copying the .homeassistant folder directly, but it doesn’t seem to work as smoothly as I hoped. Am I missing something here? Is there a proper procedure I should follow to ensure a seamless transition?
I’ve heard that using Docker volumes is the recommended way to persist data, but I’m not entirely sure how to set that up correctly. Maybe I need to map the .homeassistant folder to a Docker volume instead of just copying it over. I’ve also read that sometimes permissions can be an issue, so I should double-check the file permissions in the container.
Has anyone else gone through this process recently? Any tips or best practices you’d like to share? I’d love to hear about your experiences and how you handled similar situations. Let’s make this transition as smooth as possible!
For anyone else considering the switch, here’s a quick tip: Make sure you back up your current configuration before attempting any migration. It’s always better to be safe than sorry!
Looking forward to getting this sorted out and enjoying the benefits of Docker化的 Home Assistant setup. ![]()
