After deciding to install heat pumps in several rooms, I faced the challenge of upgrading my thermostat system. My old Nest thermostat was struggling to provide accurate temperature readings due to the heat pump airflow, so I decided to switch to Tado. Here’s my experience and some tips for anyone considering a similar move.
Why Tado?
Tado’s smart thermostats and radiator valves (TRVs) seemed like the perfect solution. They offer seamless integration with my existing boiler system and provide room-specific temperature control, which is essential with the new heat pumps.
Installation Process
- Wireless Setup: I opted for the wireless Tado kit, which made installation much easier. The room sensor can be placed anywhere, eliminating the need for wall drilling.
- Smart TRVs: Installing the Tado smart TRVs was straightforward. They connect wirelessly to the room sensor and offer precise control over radiator temperatures.
- Integration: The Tado app was user-friendly, and setting up geofencing and scheduling took only a few minutes.
Key Benefits
- Energy Efficiency: The Tado system has helped me reduce energy consumption by optimizing heating based on real-time conditions.
- Comfort: The geofencing feature ensures the house is warm when I arrive, and the room-specific controls prevent overheating in unused areas.
- App Control: The app provides detailed insights into heating patterns and allows for easy adjustments.
Tips for Others
- Plan Ahead: Consider the placement of your room sensors to ensure accurate temperature readings.
- Upgrade Radiators: If your radiators are outdated, consider upgrading them alongside the TRVs for better performance.
- Leverage Smart Features: Take full advantage of features like geofencing and automatic scheduling to maximize efficiency.
Switching to Tado has been a smooth and rewarding experience. If you’re looking to modernize your heating system, I highly recommend exploring Tado’s offerings. Let me know if you have any questions or need advice on your setup!
